Darkwood
So they only instruct after an installation has been completed and upon inspection, if one is carried out, not on the existing installation prior to work starting, which is how I read your post 5278, thanks for clarifying that point.
Yes they only inspect after by way of audit. Me as the installer is mandated to check prior to installation. If upon audit they deem the existing installation has work that needs to be rectified then yes they do instruct it is done.
I know of 2 people who were told to liaise with the DNO to get a cutout up graded and they also had to upgrade the tails.
They’re not expecting a full EICR. But they are expecting the installation to be in a suitable safe condition for the charger to be added.
Also as an installer you have to be able to say yes to the statement in the ENA form that says
"I confirm that the existing installation is in accordance with the current edition of the Building Regulations Part P (Electrical Safety – Dwellings) and in full compliance with the requirements of the current edition of the UK wiring regulations (BS7671)"
C2 Codes are not in accordance with either part P or 7671.
Regarding the above.
Somehow, I'm not seeing much wrong with this. Different, I know, but seems like a version of the old town council 'clerk of works' type system, making sure that things are done well. The main difference being that the upgrades necessary aren't involved in the original job requirements or specification......directly.
It seems like another way of putting the responsibility onto the contractor, as per usual, then providing an inspection system to check all is done correctly.
I used to get situations, whilst pricing for 'off the cuff' council jobs, where I would be expected to notify if there were any other issues with the existing installation and adjust the price accordingly.
I don't know much about it but maybe OZEV is going back to being more thorough about the whole thing....and maybe upsetting some by seemingly being a bit old fashioned.
Note. Then, all council employed electrical contractors had to be NICEIC members..................when it really meant something to be one.
Note. Then, all council employed electrical contractors had to be NICEIC members..................when it really meant something to be approved.
I agree and personally don’t have an issue with my work being checked. I am far from perfect and quite happy to be shown areas I need to improve. I like to think my work is of a good standard. But always willing to learn from the more experienced
I’m actually glad they’re doing it as it was becoming a race to the bottom with EV installs.
Customers naturally want the cheapest option possible for the same equipment. But when you have installers just throwing them onto installations in that condition, often way cheaper than I ever could as they were contracted by a big firm. Then it was affecting the quality of the workmanship and in some cases the safety.
Eg this one. Which was first installed by a so called qualified and competent installer on a 115v commando with the inlet on the supply side. So exposed live pins.
Then when it was ‘rectified it still wasn’t done correctly as it wasn’t using an interlocked socket which is mandatory in a residential setting.
But the customer saved £200 by using this particular installer.
This is another one I found on an EICR that I need to sort.
Tails are ran in SWA to the CU which in a straight line from that position is 4.5m. So will likely be circa 6-8m with the routing. The CU is in the airing cupboard which is in the middle of the upstairs with a bedroom either side and it’s at the back of the house. The meter is on the front left side of the house.
Yet there’s no OCPD for them apart from the DNO fuse. 🤦🏼‍♂️ I do wonder who designs these things at times.
I‘m hoping there’s enough slack in the cable to re-gland and terminate inside a metal clad switched fuse. Can see this being a fun one to do. 🙄
That will indeed be interesting.
Is the angled piece of board the head is on attached to anything?!
Not many small switched fuses have side entry.
I think I’d be trying to terminate the SWA shorter and crimp onto tails, then use one of those Lewden fuses designed for tails in and out as they aren’t that big. It could replace the isolator too.
I’m going to remove the isolator and put in a metal clad switch fuse. Something like this.
I can hoped drill a hole in the side of that to gland the SWA. Just may have to crimp to extend the SWA inside. But that will be double heatshrink covered if I do. Just need to hope it’s not a slide on cover that the sides come away with. Otherwise I’ll need a rethink.
Although I have a feeling that SWA may only be 16mm
I can’t really crimp it to use a KMF as I need to terminate the SWA into something.
The angled board is fastened the the back board.
Seems the fuse box version won’t work.
So will have to use this instead.
Yes, that is what I meant by most of them not having side entry.
The Chint idea looks possible.
One possible idea/suggestion. Replace the butchered Wiska box, gland the SWA to this, slide behind the angled board and change to tails inside the Wiska box, and then use a KMF?
Darkwood,
vjsmarwick,
