Darkwood
Yes a time bomb waiting to go off! This is the installation in question.
The main isolator is the one bottom right, the supply tails run in the trunking below it from the main intake just out of shot on the left.
The original work was very well done and this set up is repeated in the same building further up, it's just all the carp work done since that leaves a lot to the imagination!
This is in the next factory shop 2 rooms up from the supply intake!
Definitely a lot of C's of all descriptions in this one!
While there I was asked to look at an Anyak lathe 30kw 3phase (nice bit of kit) behaving badly! On inspection of the supply I found this!
Faulty L1 phase on the MCB not passing current through it. I was then told this trips out many times a week! Mmm wonder why!
Myself and the DNO engineer were of the same opinion as all the main seals were all intact on the cut out and metal supply intake cabinet! We came to the conclusion they either were damn stupid and incredibly lucky or they had some serious balls of steel!
Yep. Beyond comprehension is that.
Could say 'they deserved to fry like pancakes'.......to$$ers
Even with hot gloves arc protection and insulated sockets or spanners it would have been lethal and I wouldn't have wanted to trap the 2.5 under the washer! Imagine if there had been a fault on that circuit as it was connected live 😱
That's the part which perplexes me - I can't see it having been connected live, but can't imagine anyone with authorisation to shut a place down carrying out such work.
@nicebutdim I totally agree with you, but it must have been done at some point after the original installation as the rest of that original installation is very well done, the rest is a mess but that's another story!
The only thing that could have happened is that the seal fairy paid a visit in the past and at some point after that it was re-sealed again by the DNO, perhaps after a meter change.
Darkwood,
sunray,
