Dodgy trade pictures for your amusement! - 1 Million Views! | Page 499 | on ElectriciansForums
Darkwood
Its amazong how much of this rubber cable I still come across that is still in service , its fine until you touch it then it just crumbles in your fingers.
Run from the board was fine and perfectly supple and I didn't expect it to be so bad at the socket. I've seen it crumble before, but this stuff was as hard and brittle as plastic where it had fallen apart.
In my experience with VIR it aways crumbles at the end where accessories are connected to it, heat does not help, but the material will just degrade naturally over decades of time.
I am way to young to have installed rubber twin cable , what sort of age are we looking at now. some of this cable must be pushing 80 - 90 years old and still in service in thousands of homes
VIR singles were used in domestic homes 1910 to the 1950,s possibly 113 years if still in service
That socket was wired in flat 2 core cable, although lighting to room below is still insulated & sheathed rubber singles.
Yeah saw that, was dating the VIR singles because I know it was used in the early 1900s, dont think the flat twin was that early not sure. Defiantly used in the 50s as you know I would guess 1930 only because have rewired houses of that era with that type of cable.
What would you use?
If it is not inverter driven than CY or it’s equivalent polyurethane coated version.
for a stationary motor, singles in conduit would be fine (tri rated)
edit, I did not mean CY, I meant YY. Oops, CY is screened similar to Sy and not required unless there is an emc issue.
That’s my point. You did not know the application so unsure why you stated it was not fit for purpose.
What would you use?
One that is recognised by British standards
SY, CY and YY cables are not manufactured to a specific British, European or international standard so in most cases it is not possible to demonstrate the performance safety standards required to satisfy the Wiring Regulations.
I would say 90% of times I have come across braided style cables they have not been installed using the correct glands.
Near every time they have been installed like the picture using a stuffing galnd Or no gland at all
