Dodgy trade pictures for your amusement! - 1 Million Views! | Page 531 | on ElectriciansForums
Darkwood
This one is just strange.
Crabtree Starbreaker box, Hager main switch, CGD RCBOs, one Fusebox MCB, bus bar fed from bottom of main switch into one of the RCBO's by that red wire underneath.
What irks me is that it's all fairly neatly done....can't be DIY...someone knew what they were doing here.
Wiring up for an ASHP yesterday. Plumber had been in before and had his apprentice repurpose and wire the existing immersion supply. Bless, at least he tried.
I later found the immersion was wired from an existing ring final. Had to open the JB to remove cabling (then rana new circuit). Think that vermin family all died together.
  • [ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
What's the minimum bending radius for 4H4 MICC again?
Another view, the other end of these cables is very nicely installed and I can only assume this end was once. It hurts seeing stuff like this. There is no excuse, especially as these are all metric cables with new pots and glands readily available. Even if they were old imperial cable there is no excuse. Out of view some of the other cables are too long so loops have been buckled into them to 'shorten' the cables. Pathetic.
