Dodgy wiring advice | Page 2 | on ElectriciansForums
Discuss Dodgy wiring advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I dont think the casing is illegal, but from memory, they used to use these years ago where it also housed a fuse in the neutral, which IS now a big no no.
The ones I've seen had a neutral LINK not a fuse,but it did fit inside a sort of fuseholder so I can see why you could think that.Unless the ones you loked at were once supplied with D.C. The last one I came accross,a few years ago,I had to install a 10mmearth, from the screen on THEIR cable,a 10mm earth to THEIR caseing,and the guy from the lecky board said I had to install an earth spike as well.After I'd done all this(and the family remained without lecky for another day)the next day they sent a different guy out and by the time I got to the job he'd PME'd it,putting a link in from his neutral to the met,converting it from TN-S.(so I was able to put my 100ma rcd back in my pocket)
Reply to Dodgy wiring advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's the policy on this forum not to give step by step advice. If you have an understanding of wiring requirements you will not have any...
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
