Dodgy wiring in rental flat | on ElectriciansForums
Discuss Dodgy wiring in rental flat in the Australia area at ElectriciansForums.net
dodgywiring
Ive recently rented a flat that i didnt view before renting, due to being out the country.
Anyway we've moved in and its a bit of a ********.
But in the bathroom which is on the 2nd floor there is an electrical wire which leads to the electric shower that is exposed, and this wire to my disbelief is attached to the water pipes ... surely with all the regulations in England this cant be acceptable?
I know little about electrics but im presuming its not the earth wire as i believe id see the yellow green.
Anyway ive uploaded some pictures if anyone can confirm this is dangerous id appreciate it as i bathe my baby daughter in here.
PS I believe it was wired by a friend of the landlord who is a jack of all trades
  • [ElectriciansForums.net] Dodgy wiring in rental flat
It might look a bit rough but there isn't necessarily anything wrong with it provided there is no danger of the two services interfering with each other, eg hot water pipe melting the cable, or condensation from the cold water pipe dripping onto that fan heater.
In either case the water pipes should be earthed so in the event of the cable becoming damaged and the pipe becoming live, a protective device (eg MCB, fuse etc) in the consumer unit should operate before you realise what's happened (0.4s).
Thanks Novus.
Im led to believe that it would have to be installed by a certified electrician as its a rental property ... from this point of view would you say this work has been professionally done as surely any qualified sparks would be putting his reputation on the line to put his name to such shoddy work.
then it wants dressing away at the least. heat and pvc cable is not a good marriage ( bit like that busty tart, whatsherface and whatsisname the singer)
Dodgywiring, can you measure the width of the cable in millimetres, and can you see a rating label (in Watts, or kW) on the shower? It might be attached to the underside. Or even a model number? Just out of curiosity.
Reply to Dodgy wiring in rental flat in the Australia area at ElectriciansForums.net
