Does a 13A plug in oven need to be wired into a cooker switch in rental properties ? | Page 2 | on ElectriciansForums
Discuss Does a 13A plug in oven need to be wired into a cooker switch in rental properties ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Their electrician may be used to fitting Howdens ovens that no longer can be fitted with plugs according to them . There is a label on the flex with this instruction on it . They are not small ovens though.
that's just manufacturers trying to get out of replacing faulty crap. in a court of law it would not hold water. ( a bit like beko washing machines)
Hi - if it comes with a plug I’d stick with it. It could be changed out for an FCU, but if the circuit has no RCD and you need to extend it to add the FCU ...
Thanks Wilko, interesting thought ! ....and whether a minor works to swap an accessory but adding an FCU at the same time requires that little FCU to be RCD'd to be 18th compliant. Hmmm.
As far as i know, in Scotland anyway, there is no such requirement. If the manufacturers fit a plug and say it's to be plugged in, that's the way to go.
Indeed, for non-electrically minded landlords who have a hands-on approach, many prefer the plug-in option for all appliances, such as cookers,hobs,washing machine, dishwasher etc as it makes swapping out a faulty appliance quick and easy with less hassle for landlord and tenant alike. It makes ISITEE simpler too.
would not be appropriate for anchors.you'd lose so many you'd be adrift on a lee shore. every pirate's nightmare.
Certainly not appropriate for anchors, Tel! Plug-in anchor and chain is bound to fail, so I always make off the bitter end into a SFCU. This is not only more resistant to "pull" than a plug in a socket, but it means that as the anchor chain goes over a metal roller in the bow, and the forestay is connected to the roller housing, then in an electrical storm, if lightning strikes the rigging, it is diverted to the sea, shivering, but not charring, my timbers...
As for Lee Shore? Indeed, every seagoing man's nightmare...I should know...I went out with her once, in Portsmouth!
Very true, Marconi! I have changed ovens after 6 month lets because they are so filthy I couldn't contemplate a professional oven-cleaner person wanting to deal with it.
What DO they cook in there? I clean mine once a month, or so, and it always looks like new.
BTW, what do you all use to clean the acres of stainless steel in a kitchen? Fridge-freezers, ovens, extractor fans...I tried everyting from commercial stuff to old wives' remedies...and actually a professional cleaner pointed me at the perfect solution...but i want to hear everyone's views before revealing the miracle cure!
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Does a 13A plug in oven need to be wired into a cooker switch in rental properties ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
