Discharged
And if so, if a 30A relay is being used to switch power to the element, does the supply to the relay need to be 2.5mm as well?
It is not allowed to connected a water heater via a plug or socket arrangement.
Hi. Not wanting to be confrontational but , i have always connected elements with 2.5mm2 cable with a d/p neon ,and a fused spur at the tank , with 2.5mm2 heat resistant flex to the immerser
However the wife has a horse or 6 and she got a rug dryer
Heated horse rug driers - Products
and as you can see in the picture its is basically a short element with 2.5mm2 rubber flex onto a rubber plug top
so is this illegal
Jamie
