Does anyone know what type of fuse this is? | on ElectriciansForums
Discuss Does anyone know what type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
wokingham berkshire
Does anyone recognise this fuse. It comes from a punch machine , made in Spain, bought in the UK and exported to Canada.
Thanks,
Mike
[ElectriciansForums.net] Does anyone know what type of fuse this is?
Looks like a lamp, not a fuse.
FYI, in some machine control applications, a lamp is used as a current limiter to an inline device.
Looks like a neon indicator.
Sometimes used to be used in triac firing circuits, so could be that? Just a guess though.
Any chance of a clearer picture and/or more information about the machine and which part of it this is connected to? Agree it is not a fuse.
Now I see it on the bigger screen, surely it is a panel-mounted neon indicator lamp as mentioned above. Maybe it got smashed and they assumed that what they were looking at was the remains of a panel-mount fuseholder.
Still looks like a neon indicator though. How is it wired - is it in series with a live feed, or does it have a live and neutral to it?
Sorry, the machinery is in Canada and I'm in the UK. Relying on photos being sent.
They have sent details of a fuse which is 30mm long and 15mm diameter. The thing (the suspected neon tube part) in your photo looks nowhere near that size.
You need better info from them, or an electrician on site I reckon.
That is exactly what I have told them, their electrician doesn't seem too keen to help!
Hi, more photos sent.
Fuse 16amps, length ~30mm, diameter ~15mm
The photo shows the "thing" wired with a red wire on one terminal, and a black wire of smaller diameter on the other.
Doesn't make much sense for a series circuit, which one would expect to have both wires the same colour and gauge.
Coupled with the earlier pic of what we think is a neon, it's stacking up in favour of 'indicator' rather than 'fuse'.
If you know the size of the hole (is that the 15mm??), you could send them an example of both🤪?
Reply to Does anyone know what type of fuse this is? in the UK Electrical Forum area at ElectriciansForums.net
i think dan was referring to the OP where they mentioned it was found when removing mirrored wardrobes.... maybe nothing to do with the mirror...
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
