Does polarity matter for an RCD? | Page 2 | on ElectriciansForums
Discuss Does polarity matter for an RCD? in the UK Electrical Forum area at ElectriciansForums.net
Steve T
Newcastle
Hi all,
I recently was given an old 2 pole Legrand RCD meant for the European market but it doesn't have any indication of which side is neutral and live, and also doesn't indicate which side the supply and load go into. A picture is attached. I've looked at the data sheet which doesn't provide any info.
Does that mean the polarity is not important nor which side the supply and load go into?
Thanks for any replies!
[ElectriciansForums.net] Does polarity matter for an RCD?
I don't see how this would work at all. The entire load current would be sensed twice as an imbalance so the RCD would trip at 15mA load.
Maybe it did, but this was a 100mA RCD IIRC, so 50mA. Wouldn't be a problem with an installation in good order.
I replaced the RCD, and moved the neutral in to the top, as it should have been.
Reply to Does polarity matter for an RCD? in the UK Electrical Forum area at ElectriciansForums.net
Spot on The Requirements of sections 1-6 must be complied with in a special location unless its otherwise stated in that part of section 7 that a...
I'm going to get the wording wrong because I am far too lazy to look it up. A previous version said 'must be followed' now says 'should be taken...
