does this comply? | on ElectriciansForums
Discuss does this comply? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gibbyisking
been ask to change a fuseboard. the fuseboard is supplying 5 storage heater circuits each on a 20A breaker. It is on the off peak supply. Plan is to put a 8way 80A 30ma RCD unit. Now is this ok or does the fuseboard have to have a main switch?
As above, but if thats the road yer goin. Most dual rcd boards are under 50 quid these days fully loaded. That way you have yer mainswitch, and better discrimination. At least you wont lose the lot in the event an rcd tripp. Some heat is better than none in this weather brrrrr.
Reply to does this comply? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
