Does This Installation Look Correct? | on ElectriciansForums
Guest viewing is limited
Discuss Does This Installation Look Correct? in the UK Electrical Forum area at ElectriciansForums.net
Midlands
Hi all,
I wondered if you could give us your thoughts on our friend's installation? I've included some photos. We're sure that there's something wrong with it, but we wanted some expert opinions.
Here's a bit of background:
An electrician changed the original split distribution board and carried out an EICR. Prior to the CU change, the upstairs and downstairs lighting was on two separate circuits and apparently, the lightbulbs would often blow. That's not the case now. The tariff is just on a flat rate, so our friend doesn't benefit from lower tariff through the night.
It looks like the earth clamp is a BS951 (see bottom photo)
Can you tell us if all looks correct here, and if it's not, should the DNO be the first contact?
[ElectriciansForums.net] Does This Installation Look Correct?
Reply to Does This Installation Look Correct? in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
Recommended Sponsor News
Hi everyone,
