Does this proteus RCBO fit this board? | on ElectriciansForums
Discuss Does this proteus RCBO fit this board? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Morning all..
As in the title does the RCBO below fit in the proteus board shown in the second picture.
I'm sure it must do but I just wanted to be 100% sure before I turn up to the job.
[ElectriciansForums.net] Does this proteus RCBO fit this board?[ElectriciansForums.net] Does this proteus RCBO fit this board?
Also, in case I buy a different proteus RCBO, do they all fit this board? The reason I ask is because there seems to be lots of different looking proteus RCBO's as in the pic below:
no way of knowing, but it should fit unless the pillocks have altered the physical configuration.
I'm taking that as a guarantee that it does tel! I was about to say that you'll have to buy me another one if it doesn't, however I can't even joke about it seeing as though you sent me a free one the other day! :D
The guidedogs got their tenner by the way.
What’s a guide dog going to do with a tenner?
i sent happy a rare component free, subject to a donation to guide dogs organisation. and thanks for that happy.
Your best bet is to ask the manufacturers, we had to get an MCB for a Crabtree Starbreaker consumer unit (plug-in type) the board was about ten years old but they had updated the MCB in the meantime more the livery on it but is fully compatable and type tested to go in older boards.
Not to my knowledge they have always had their own factory, however, it could be that they produced the board but got the isolators and protective devices from a 3rd party. I have noticed that a lot of protective devices are identical albeit the cosmetics.
Most Proteus gear is and was manufactured in Telford and Redditch UK by CEF in house factories much the same as Tamilte RPP Tamlex Centaur trunking.
Used to frequent their factories in the mid 90s while employed by one of the branches!
Don't think that will fit but always happy to be proved wrong, but the pic of the board is probably mid to late 90s!
Yes it will fit. They also make a compact RCBO which will fit.
I could almost hear the rest of the unwritten words then LEE... :D
What are you guys going on about, just answer the question, Yes it will fit!
No offence chaps :wink:
Reply to Does this proteus RCBO fit this board? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
5K
