Does this seem reasonable? | Page 2 | on ElectriciansForums
Discuss Does this seem reasonable? in the Australia area at ElectriciansForums.net
Large 3 bed house
Dont know what to say to person who asked me. really seems like it could be a fairly high price but not out of ordinary bad.
35 double sockets (all chased and made good)
2 x floor heating supplies 13amp
3 x Cooker Supplies. (2 ovens,1 ceramic hob - each 32 amp)
Boiler supply and controls
Alarm supply
Smoke + Heat detection, hard wired.
2 x extracts
1 x over head extract supply
45 x down lights (all in lath n plaster)
8 x IP shower down lights (in lath n plaster)
All lighting apart from 2beds, utility and bath to be run from Wireless control units with multiple zones
Fittings (Downlights only) and intelligent lighting system client provides, Just fit, wire and program.
2 x outside PIR flood lights
Audio cables run in to locations for speaker system (bed, Kitchen, dining, lounge)
Main earth bonding
13 way CU (crabtree)
All Sockets switches isolators anything visible is in G&H white powder coat flat plate metal (ÂŁ10:50 each double socket, ÂŁ500 for all)
G H FW10W Flat Plate Matt White 2 Gang Double 13A Switched Plug Socket - Ashdown Light Store Switches & Sockets
Total cost : ÂŁ7000
you can buy the cowel thingy seperatly If memory serves me right itd something like "Dust Elimination Tool" I got one from CEF Slow speed on drill new holesaw dont put to much pressure on it
The lighting control,wiring to control boxes and speaker cables ( mind run these well away from mains as interferance WILL happen if run to close ) probably wont be simple allow extra time for this Had a jod few tears ago client speced Wandsworth flat plate fittings we had to fit 35mm back boxes due to ammount of the fitting behind it (allow for extra chasing and cutting out the boxes and PRAY its not black brick or dry old mortar that cant be chased without wall falling to bits ( Ts N Cs to cover this)
The link you put up seems an expensive place to buy gear, sure you could better them prices ... tool station , Sfix or a local whole salers, or is that make specified ?
Ste
Make was only one could find that cheaper white powder coat flat plate, BUT with WHITE rockers, all cheap ones i found were silver or chrome rockers......any links appriciated
Have a look at toolstation they have two adjustable hole saws which also have a cowel to catch the dust, have used one for years. Plus they come with different blades for different materials. Just done a job and it didnt damage any of the other lathe ceiling as it can be a bit fragile in older propertys. Plus they save you getting a face full of dust and soot.
Dust dont matter so much as not occupied BUT i would prefer much less on AND in my eyes nose mouth etc etc
i just use one of these........
images
Yea absolutely Pict, i usually just keep one of these in the van...my last one broke recently though when making up my lunch for the day and cutting its finger when slicing my sarnies up. having a hard time buying a newer replacemenet as apparently Slavefix are no longer in business? weird that
images
Reply to Does this seem reasonable? in the Australia area at ElectriciansForums.net
Depending on the location of the 2 CU's and the quality of materials I'd say ÂŁ10K-12K. If they're potential tyre kickers don't waste loads of time...
    • Informative
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
