Doesn't make sense!! | on ElectriciansForums
Discuss Doesn't make sense!! in the UK Electrical Forum area at ElectriciansForums.net
P
phil94
Hello everyone this is my first time on this forum and I'm looking a bit help!! I'm starting to think I'm a complete idiot!! (Maybe I am??)
A simple apartment block intercom system, has a 12V AC supply. Is it possible, for a DC door strike to operate properly?? I can't see how it could, but need confirmation?
All help appreciated :)
Don't worry about it bonny lad ... With those qualifications you'll fit in well here. :)
Welcome to the asylum - it's your round and mine's a Broon. :8:
I'm didn't install the system, but the apartment was broken into so I am responsible to fix it.
The system that has been installed is a Bell 906 Door entry system with Lock Release.
I got the instructions over the Internet there, and they were really helpful:)
But what would really happen if a 12V DC door strike was wired into a 12V AC voltage supply? Would it work as an 12V AC door strike?
Sorry thaught I had explained, yes it will work ok, the reason a dc strike is used on an ac supply is to make the strike buzz aswell as opening the door, its a quick way of telling the caller he can now enter by pushing the door. If a dc power supply were used, the would be no noise just a faint click.
This is a quick wiring diagram of the intercom system I am doing atm, and the problem is that the door strike will not release?? I'm completely baffled?!
  • [ElectriciansForums.net] Doesn't make sense!!
Phil there should be not connection from AC- 26 to door strike, should be 1 wire from phones to - door strike only.
1. check voltage at dc and ac terminals on psu, 2. check voltage at door strike. 3 would suggest as manufactures states using ac supply only. I think if you test voltages, you will find ac output not working
There is no AC-26 connection anywhere on the diagram, there is an AC 22+ and a AC 24- connections though.
1. Checked voltages at both AC and DC on the PSU, and both reading 12V
2. Checked voltage at door strike and it was 12 AC as well
So unfortunately that hasn't worked?
Just so I have it clear in my easily confused head, I should have a AC + supply going to the + on the door strike and in the - terminal of the door strike I should have a cable going to the phones?
Phil
Reply to Doesn't make sense!! in the UK Electrical Forum area at ElectriciansForums.net
I would have to agree with @James to hire an electrician to measure the voltage coming in to the panel. If you have 240vac phase to phase then you...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
