Doesn't make sense!! | Page 2 | on ElectriciansForums
Discuss Doesn't make sense!! in the UK Electrical Forum area at ElectriciansForums.net
P
phil94
Hello everyone this is my first time on this forum and I'm looking a bit help!! I'm starting to think I'm a complete idiot!! (Maybe I am??)
A simple apartment block intercom system, has a 12V AC supply. Is it possible, for a DC door strike to operate properly?? I can't see how it could, but need confirmation?
All help appreciated :)
Phil sorry remove ac 24 as the phones supply the - when you push the phone entry button. From your diragram is the fault that the door is staying open all the time, if so removing ac 24 will sort that
Diagram of your pic, hope this explains better
[ElectriciansForums.net] Doesn't make sense!!
Whenever I remove the AC 24 - supply the door strike doesn't operate at all, and whenever the AC 24 - is connected the door strike is always closed but will not release from the phone handsets?
The thing that confuses me is that bell and the speaker all ok perfect, but its just the door that doesn't release?!
What should the AC 24 - be connected to? I know this is probably a nightmare trying to figure this in your head, but any help at all gives me an idea to sourcing the problem:)
No it not a nightmare from your picture a can see whats going on.
when you disconnect ac 24 does the lock stay open ie the door is free to open and close or does it stay locked.
Right there is the answer, the wrong lock has been installed, you required a fail secure lock, you have a fail safe unit. You can test this by removing the ac - 24.
there should be not voltage at the lock. When the entry button is pressed on any phone you will then get a voltage at the lock.
Aha tazz!!!!! That sounds like the problem!! I will have to try this out tomorrow, but that seems to me what is wrong :)
So just a quick general question, whenever you want to be able to release the door strike from the phone handsets there HAS to be a fail secure lock installed? Is there any way to wire a normal door strike to operate in the same way?
Yea thats what it sounds like to me, I shall go to the job tomorrow and see if that solves it and I will let you know:)
Thank you greatly for all your enlightenment, I really appreciate it!!!!!
Reply to Doesn't make sense!! in the UK Electrical Forum area at ElectriciansForums.net
M
Rubi DC-250 1200 Water Pump Replacement Hi, I'm really hoping someone can maybe help. I have a Rubi DC-250 1200 and it looks like the water pump...
mattwaddy
M
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
