Hey all, I have a couple of jobs to look at which one is apparently not working right as is a single phase supply through a D.O.L starter / contactor for I think a borehole pump and another that is running a fresh air ventilation system and is now tripping out ! The thing is I've never needed to fit one or wire one so don't have any info on how to. The two jobs are for a friend and a friend of a friend so won't be charged as such.
Also apparently the pump one the girl has said the green start button doesn't do anything and only the stop button does stop the pump usually but if you let it go the pump runs again and doesn't stay off unless you twist it to lock it off ? sounds like the contactor is not wired right anyway ?
I have done contactors similar on A/C plant before which were 3 phase but wired for single phase supply where I had to link one input across to top of 2nd phase to balance the overload or it would trip. Is it likely that the ventilation one could be tripping due to a faulty overload or maybe faulty fan or failing fan ?
Anyone got any diagrams of the wiring for the contactor as direct on line or the coil connections etc.. or through a start and stop button system please?
Any help gratefully received and pints owed.
