Discuss DOL starter wiring problem in the Australia area at ElectriciansForums.net
Yes will try thatI wouls start with disconnecting the load to see if the DOL is wired correctly
I’ll wire it up as per your diagramTry referencing against this, out and about ATM so can't get them up side by side to verify myself.
There is also the very real chance you've not set the overload correctly, I'd start with that
I’ll wire it up as per your wiring diagramTry referencing against this, out and about ATM so can't get them up side by side to verify myself.
Reply to DOL starter wiring problem in the Australia area at ElectriciansForums.net
