DOL starter wiring problem | on ElectriciansForums
Discuss DOL starter wiring problem in the Australia area at ElectriciansForums.net
Mandurah
Hi I have problem wiring up DOL starter
Circuit trips breaker when try to start
I must be wiring something wrong
Any help would be appreciated
  • [ElectriciansForums.net] DOL starter wiring problem
Try referencing against this, out and about ATM so can't get them up side by side to verify myself.
There is also the very real chance you've not set the overload correctly, I'd start with that
Reply to DOL starter wiring problem in the Australia area at ElectriciansForums.net
Thanks Sorry, first time forgot the attachment
I believe that it is incorporated into the 5 days. But will double check. Thanks.
