Domestic 3 phase | on ElectriciansForums
Discuss Domestic 3 phase in the Domestic Electrician Forum area at ElectriciansForums.net
Visited a job today, barn conversion approx 10 years old. Property was agricultural barn to start hence 3 phase supply. It appears that most rooms have at least two phases in them, sockets and lights. Is this common practice and acceptable ? If I had done the work I would have kept the phase in each room the same, It's not even really necessary to have 3 phase, its definitely not balanced as all the lighting is on one, and the property is not that huge.
Sorry, question is is it ok to have different phases in the same room in a domestic environment ?
If there's no longer a need or justification for the 3ph, then all you need is a Henley block at the source! Join the two downstream feeds together into the one phase and get the DNO to disable the other two phases - hence saving your customer significantly more than the cost of twenty minutes of your time to do it!!
NOTE: The above assumes an awful lot and that you've tested and inspected, no problems with neutrals, earths etc etc.
Reply to Domestic 3 phase in the Domestic Electrician Forum area at ElectriciansForums.net
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
