C
craig1000
Hi All
Have been asked to check out the smoke alarms in 4 domestic properties & provide a annual certificate for said work!
Haven't done this before just want pointing in the right direction?
In both the NAPIT & HOLYCROFT certificate packages I have I have a cert for annual testing of commercial FA systems but for a domestic dwelling I only have install FA certs?
What cert should I use?
Cant see the need to be recording much as all I can do is check test button & all detectors operate, smoke them all, & visual surely! could drop them all off & R1+R2 & IR test the circuits also but these are really electrical cert checks!
Any advice would be great, I am sure it can be argued by some should I be doing it if I don't know but am sure I am competent if pointed in the correct direction! ;-)
As with anything if you haven't done it before you wont know, & you wont know until you do it!
