Discuss Domestic Board schedules in the Domestic Electrician Forum area at ElectriciansForums.net
With advise from Nic ive been sellotaping an hand written board schedule to the front of the new board in peoples houses which I must admit looks a bit of a mess. Am I missing a trick or is this what you all do?
cheers
cheers
You would put a laminate copy of the results on the wall next to the board in someones hallway or where ever?dont think my customers would be happy with that.Just as part of my service I would print of another copy of the schedule of results from the BS 7671-2008 laminate this and then punch 4 brass eyelets through it and then attach this at the origin of the installation.
Commerical boards or industrial becasue they are normally larger I would do the same laminate a copy of the results but glue an A4 plastic envelope inside the front cover of the DB abd then place the laminated copies inside this.
Reply to Domestic Board schedules in the Domestic Electrician Forum area at ElectriciansForums.net
