I have a 13 amp socket in my kitchen which, from behind the switch plate a green sticky substance appears occasionally on the wall. I have just removed the socket plate and revealed that the substance appears to be coming from the three core wire sheath.
I suspected one of the core cables was overheating but the socket is never overloaded and is in continual use and has never shorted out.
Could anyone please tell me what might be causing the problem. I guess the cure will be to get the cables replaced.
