Domestic Consumer Unit | on ElectriciansForums
Discuss Domestic Consumer Unit in the Domestic Electrician Forum area at ElectriciansForums.net
Sparky@Hu15
I recently visited a new customers house and was giving the electrics the once over. The consumer unit was mounted on the wall vertically (top pointing East-bottom pointing West) as opposed to horizontally, is this good practice & would it affect the safe operation of MCB, RCD, RCBO and the like?
Welcome to the forum :)
In a nutshell, no just ensure any required IP ratings are maintained, electricity isn't really fussy about gravity, my only comment would be any objects that fall on the breakers should not inadvertently switch them on now this would require the board to be upside down to do so.
Reply to Domestic Consumer Unit in the Domestic Electrician Forum area at ElectriciansForums.net
thank you it really made me feel small, maybe i played it a bit thick, but as the one needing the work done i was cap in hand, will try another...
2 3
