Guest viewing limit reached
Hi Guys,
just wondered what everyone thought was the best domestic consumer unit in your experience and what would you put in your house.
Looking to re-wire my house and don't know whether to go with wylex or mk.
thanks
Craig
I have been fitting a few Contro lGear units lately, they are a bit cheaper than others and do the job okay. But I am about to replace an older Merlin Gerin unit in my own house to 17th split board and have opted for Hager. A bit more expensive, but very neat and I particularly like they way they acheive the IP4X for the horizontal top surface.
i like the contactum CUs, but they change the profile of the breakers every lunch time so you end up with 3 different styles of MCB in the board. looks totally unprofessional. ( and if i've spelt that correctly, i've not had enough)
funny you should say that. got a starbreaker board cheap, fully loaded, £10, going to fit at home when i can get round to it.
MK all the way for me unless a little tight for space and then I use Wylex. Forget bringing tails in from the bottom and up behind the main switch. No room and a mass of RCD cables in the way. Apart from that they are a sturdy board.
Fitted a Crabtree once.
Fitted a Control Gear once.
Wylex or Volex normally in that order....And Megger all the way! ( oh and cadbury giant buttons.....or Revels..in that order whilst fitting it)
Liverpool
Domestic Cu's
Domestic Electrician Forum
hoppy,
Amp David,
