P
Phaze-3
Hi Guys,
Take a look at the picture below. (you may have to turn your head as i couldn't work out how to rotate it it).
As you can see, the DB has seen better days so i am going to replace it with a nice new one with plenty of ways.
I don't get to involved with domestic work as i really only work with industrial installations and bigger stuff. Few questions you guys hopefully will be able to help me with. I will just add that this is a TT System to this house.
1) How far does does the main intake and DB need to be away from the Gas Meter?(As you can see, it is pretty close)
2) I done a Ze on the existing board and was getting a silly reading! Do i need to be looking at installing a new earth rod? If so where is the best place to put it?
3) Choosing a new DB. I was thinking of getting the usual 2 x RCD split boards. Now do i need an RCD Main Switch to feed the Split board (if that makes sense). and if i do does that main switch ideally need to be 100ma?
or
4) can i put a normal DB in with a 100ma main switch and RCBO's to feed each circuit.
I've been a spark for 14years but only ever work on industrial installations and dont know that much about the domestic side of things these days. There are just a few little question im just not sure about when it comes to some of the regs that are involved in domestic installations.
Cheers Guys
Steve
Apart from mains and distribution sub-main cables etc, i can't think of a single example where a final circuit on any TT system would not require a 30mA RCD type protection. Nothing else is going to trip that circuit out in the disconnection times required on the occurrence of an earth fault...
How about a final circuit with a stable Zs below 200 ohms?
No reason why a final circuit not including socket outlets or buried cables could not be protected by a 100ma rcd rather than a 30ma rcd on any TT system.
no reason at all as long as disconnection times are achieved.
That was another question i ment to ask earlier as well but forgot. I have no idea why there is a time clock. Economy 7 does spring into mind but i can't see why they would have it at this property.
Anybody got any ideas??????
They dont have any off peak dedicated system like water heater or storage heaters but they most likely have a split bill and duel rate meter, so if they have a time clock on their water heater or washing machine they can benifit from cheap rate for the times the clock is set to.
Domestic DB
Domestic Electrician Forum
Phaze-3,
D Skelton,
