davidcaulfield
Hi guys in wiring a little bedsit with en suite. I'm running in a 10mm submain from another DB as its the only thing close enough. There's only one heater and 3 sockets and a 8.5kw shower in 6mm :-( do I run a separate earth with my 10mm submain? I normally do when I do 16mm submain.
Also I am putting a card meter on before the CU. what do people usually terminate the 10mm submain into before chaining it into tails. I don't want to put the 10mm straight into the card meter as it won't be double insulated cables and will look ****
