Domestic extractor fan problem/question | on ElectriciansForums
Discuss Domestic extractor fan problem/question in the Domestic Electrician Forum area at ElectriciansForums.net
K
Kate
hey,
Hoping someone may know more on this than I do. Extractor fan above a shower in an en-suite, in-line fan so unit is up in the loft.
I know you can get condensation and "dripping" from the unit. How bad can this get?
Had a customer ask me to look at why their fan had stopped working. It was only 2 or 3 months old. Jumped up in the loft, removed the duct, could have easily filled up 2 buckets with the amount of water that came out. Travelled from the roof tile, right through the duct (had a drop point here) through the fan unit itself, into the duct on the other side. There was another drop point here which had stopped it from entering back into the shower room!
I may be completely wrong, and tell me if I am. But to me, that's far too much water for condensation surely? I was thinking faulty roof tile as this was existing and many many years old.
Hum.... We had a small problem and I cured this by putting some loft insulation over the ducting....
IS that a "cheap" low powered fan? We have high pressure units if thats any help.
If the run is long could you raise the fan at all?
Those fans are weedy as you can get, you need something like a manrose mixed flow ...
An insulated duct can also help as Murdoch says, you can buy preinsulated double skin stuff.
also make sure there are no dips and wells where moisture can collect.
I can change it up in the loft to fix the issue, just trying to find out if could be condensation, or a faulty roof tile?
Just seemed a lot of condensation if it is?
Had a lot of problems with condensation until a while back we changed installation practice. I remember one that filled half a bucket just months after being installed.
To prevent install the fan as close as possible to the internal ceiling vent, that prevents water in the duct being sucked into the fan. The long duct should be on the outlet side of the fan. Raise the fan up so that there is a fall on both ducts. Stretch flexi duct taught so that there are no sags to collect water, the weight of which will increase the sag and the water collection. Insulate exposed duct in the roof space.
Despite the above precautions I have still known water to collect and have now completely abandoned flexi duct in favour of solid for the main run but still adhering to the above principles. If you explain the problems with flexi to customers they are usually prepared to pay the small amount extra for a solid duct.
Reply to Domestic extractor fan problem/question in the Domestic Electrician Forum area at ElectriciansForums.net
Thanks for your advice guys. very helpful
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
