Domestic fuse boards | on ElectriciansForums
Discuss Domestic fuse boards in the Domestic Electrician Forum area at ElectriciansForums.net
dinger809
Essex
Hello chaps, looking at different boards for dwellings. MK don’t make them anymore, Schneider are hit and miss with knockouts knocking out and the wholesaler “own brands” ( the ones they push) can be somewhat tight. I’m looking at Hager and wondering on views, before I commit to buying the 12 I need for a job I’m about to start. Many thanks
Hager are very good quality in my experience. Heed their testing instructions if buying their type A DP RCDs though.
Hager have now changed their approach on their A type rccb’s and are now manufacturing them to be tested at 150mA rather than their previous 250mA range.
I’ve been Wylexing with their prebuilt SPD range and their new(ish) compact A type SP+N RCBO. The finished unit is not cheap but they are compact and good quality so if the job can afford it that’s what I use.
I costed the same set up with Hager gear yesterday. 8 RCBOs saw it at just over ÂŁ300.
Not cheap at all. Or I need to pester my supplier more ?
Before I packed it in, I used to use MK. The last CU I replaced I used Hager, but it was not cheap, compared to the MK stuff and that was dual rcd.
Perhaps MK jacked it in, cos they couldn’t cure their slanty mcb’s etc :)
Ive a Hager Cu in my garage, which I’m converting to a habitable room. So I’m thinking of changing to a Design 50, to customise the lid. Thinking it ain’t gonna be cheap?
Cudis CPN, or Fusebox are well priced and the quality seems reasonable for both.
Both options for 8 way with SPD fitted are around ÂŁ160 all in.
I can't justify or see the value in paying double for Hager when there is hardly any difference in quality.
Reply to Domestic fuse boards in the Domestic Electrician Forum area at ElectriciansForums.net
