View the thread, titled "Domestic, kithchen rings and fridge/freezer circuit" which is posted in Domestic Electrician Forum on Electricians Forums.
I
isitnow
Does anyone put a fridge/freezer circuit on its own radial or do you just make it part of an appliance ring in the kitchen?
Last time i wired a kitchen the drawing showed the fridge as part of a small ring for appliances in the kitchen.
I seem to remember when the 17th came out there was the issue nuicance tripping if the fridge was rcd protected another item on the ring could trip the sensitive rcd and it couldve spoilt the food
then it was mentioned that we should put the fridge on its own circuit when split boards werent dual rcd protected, but obviously theres the 50mm deep issue or use metal capping or so on but now we have dual rcd split boards so whats everyone doing about this these days then?
The original point i was making was that it would be easier to surface run it or put it on its own RCBO which tel had already suggested............
Reply to the thread, titled "Domestic, kithchen rings and fridge/freezer circuit" which is posted in Domestic Electrician Forum on Electricians Forums.
