Domestic lighting issue? | on ElectriciansForums
Discuss Domestic lighting issue? in the Domestic Electrician Forum area at ElectriciansForums.net
M
macka09
Hi guys, I'm not an electrician but after some advice please. I've replaced a few light fittings today but have hit a stumbling block. The kitchen lights existing wiring has 3 main wires going to it, but one of the black wires has been snipped. So I'm left with 3 red, 3 earth and 2 black. Is there anything I could do to rectify?
Make sure it is isolated then connect it up exactly as it was before you took it apart.
Call an electrician on Monday and get them to sort it out.
Electricity kills in a fraction of a second, don't risk your life or the life of your family for the sake of a call out charge.
That's what's in the kitchen. Photo taken without the block put on.
I could take a look. I have asked a sparky to come and look at it. I tend not to do much with electrics apart from the very basics. I assume you have noticed the black wire (neutral) is missing? Why would they do that? As previously mentioned the old strip light worked before!
Reply to Domestic lighting issue? in the Domestic Electrician Forum area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
Thanks again for your help, now solved đź‘Ť
