View the thread, titled "Domestic Lighting - RCD protection" which is posted in Domestic Electrician Forum on Electricians Forums.
FatAlan
Trainee
Supporter
Coming across a few installations with no RCD protection. How are folks finding it out there when doing minor alterations / additions to existing lighting circuits with no RCD protection bearing in mind 18th Edition requirements. Appreciate every installation is different. Are folks replacing MCB's with RCBO's, replacing whole CU's or where appropriate using RCD FCU's. Should imagine this is going down well with customers.
I have got approval from NAPIT to use devices to BS7288, which relates to RCD sockets and FCUs in a range of situations.
I am not the only one on this forum to have clarified this point by asking my scheme for advice.
No member has reported back that their scheme do not advise on their continued use, that I have seen.
For Christ sake phone your scheme, if you have one, that's what they're there for.
Ooh, I'm getting all unnecessary now, time for a lie down.
In all my years I have never contacted any scheme for advice.
I find it very liberating, sometimes it pays not to over think things and ask the people you pay to do the thinking for you.
I know not all sparks are scheme members so on the available evidence to them your stance is correct.
Good innit.
Yes
...and be at the mercy of exlisting faults or borrowed neutrals.
Also, and not sure on this as it's additional protection, changing the circuit protection would make you responsible for the rest of it.
No thanks, RCD FCU at spur.
How about an RCD fused spur off an RFC for an outside lighting circuit? An addition to another circuit that in its own right also now requires an RCD?
If your company is with a scheme, ask the question.
Myself, I see no issue but then I've asked the question of NAPIT.
An RCD spur at the origin labelled clearly would be better then hiding a spur in a loft or cupboard and as we need to ensure the whole circuit is protected and satisfactory then cost effective too ?
Reply to the thread, titled "Domestic Lighting - RCD protection" which is posted in Domestic Electrician Forum on Electricians Forums.
