Guest viewing is limited
S
SW1970
Hi folks, when carrying out a domestic PIR, do you include an inspection of the central heating immersion heater for old style single contact type? (Of course assuming that fixed wiring up to the immersion is tested as normal). If yes:
1. If it is old style single contact, what code would you give? (Feels like a 4 but because of potential danger might be a 2?)
2. Do you recommend replacement immersion to include a latching over temp thermostat contact by an electrician or that it should be done by a central heating engineer or either, or do you simply recommend that it is inspected by a competent person in central heating matters?
3. If the immersion is fed by an FCU (because it previously was supplied from a ring final circuit), but is now correctly supplied by a dedicated radial, but still has the FCU in place, am I right in thinking that the FCU should be replaced with a DP isolator, and therefore the wiring up to the appliance (the immersion head) must also be tested?
There was a thread on another forum about this a few years ago but was referring to 16th. Many thanks, SW
the old style immersions are mentioned in the IET guide to PIR's and if i remember right are a code 2 as it could just keep boiling the tank, which if you've ever touched copper at 100 celcius you will leave a lovely palm sized piece of skin there...! (that is dangerous to all you S&M fans out there!!)
regarding the fcu. an fcu is normally a double poled switch anyway (under normal circumstance anyway) and yes that wiring should be tested as well.
hope that was helpful to you
it takes about 3 minutes to swap the stat for one with an overheat cut-out. i'd do it while i had the lid off.
non-safety stats are a code 2 in the ESC guide and should be replaced (esp if it's rented). A young girl was killed by one a couple of years back, when a 50 gal tank of boiling water came through her bedroom ceiling. It was a council property too, that had been refurbished!!!
FYI most fcus are single pole - check it with your tester next time you have one in your hand!!
I don't replace fcus with a switch as a matter of course, unless I'm replacing the immersion in which case it gets a new switch and flex too.
I know that the non switched FCU are often single pole but I always thought that the majority rather than a minority of switched FCU were double pole, but I live and learn
Old style immersions get a C2 (PIR) from me.
I always reccomend replacement for a new one with the relevant stat/overheat protection etc which I do myself also.
I find once you explain the possible consequences to the client, they are happy you did.
Guys I hate to disagree but coding an immersion as a 2 because it has its original stat fitted does not add up for me my understanding is as our regs are not retrospective because if they were we would all be loaded with all the sorry this is not up to the current standards you will have to get it fixed so next time your are in a house with 3036 fuses or CBs but no RCD again this is not a fail. I myself have been called out twice to 2 properties that were built just before the regulations changed and reported to the owner or landlord yep your thermostat is not working I carry a spare 7"" and 18"" in the motor I will have to replace it and be advised it is the new safety model that has a high temperature trip built in so that now your property complies or in other words it was as our American cousins say Grandadded in and the new regs come into affect when "Alterations or modifications take place"
That's right, but it depends on what is the reason for the PIR being carried out. Quite often I find the domestic client wants to know "if it's safe". To me, that translates to: "to ascertain compliance with current regulations". The reason I take that approach is because it was probably safe when it was installed, and therefore unless something has failed, it still is safe, but the regs have changed and now it could be safer. Client is usually happy to compare with current regs after that discussion.
So to change the stat do you need to empty the tank and change the elements too. As in 1 unit??? My mothers house water goes over 100 degress... Bet ya old type with no stat in
I have to admit that I'm a bit of a Saltie (Marvo may know what i mean here) about the immersion heater and a code 2.
If we apply the logic of it then the most it should be is a 4 and that to reg 554.2.1 concerning the prevention of temperature rise and the use of a device to prevent it.
The thing with immersions is that the ESC have guided us to give an immersion without a hi-limit stat a code 2 and if we depart from their guidance, and something happened we would not win the argument that it was at most, a code 4. So we code it a 2 and I don't think we have much option.
The immersions I am referring to carry no stats at all therefore are inherently dangerous as no overheat protection at all is offered.
There's no requirement to have a t/stat with safety overheat in place unless the storage tank is plastic in which case a code 2 would be appropriate.
Domestic PIR - extent of immersion heater inspection & testing
Domestic Electrician Forum
SW1970,
oldtimer,
