F
freedomrun
Domestic PIR (TN-S, 60A MAIN, 16MM EARTH, MAIN BONDING 6MM). Neutrals on end to end test at a S/O give zero ohms, Live gives 0.30 ohms & cpc gives 2.7 ohms at same S/O. I'm thinking that if this is a ring then the Neutral is loose somewhere on this cct. Any advice please - i may be overlooking the obvious - (i have measured 230v at all S/O on the cct) - Thanks.
