Hi all
normaly on my rewires i do ring finals but on the rewire i am about to start in april ( 3 bed semi ) i was considering using radials for the sockets using 4mm t&e and 32a mcb just want to know is any one eles out there rewireing domestic properts using radials or sticking to ring fianals ??
Richard
Im also swaying more to radials these days....
It annoys me when you find like 2 sockets and someones wired it as a ring, Ive seen one socket on a so called ring!!...people think sockets and then think ring...open your minds...not directed at anyone on here by the way...
well this just reinforces the argument for using the most APPROPRIATE layout for the situation encounteres now doesnt it.....
Certainly wouldn't use a radial on the downstairs outlets, but probably fine on the upstairs low usage areas. But as Glen has stated you design your circuits to suit the requirements/layout/situation your dealing with, .....and not the other way round!!
Those that keep going on about the ease of installing Radials over rings and why they use them, are just telling me they have trouble testing and fault finding. As for the nonsense about easier to add outlets at a later stage, i think they must be talking about extending from the last outlet, certainly no different to a ring circuit elsewhere...
Living room and bedrooms on there own 20/25a radial and kitchen on32a ring if there is a sitting room or other room downstair then put seperate radial for that, the main reason is that if there is a fault on one the rooms the whole of downstairs is not lost and you have more than 32a shared between downstairs.
With the testing i wouldnt say it easier to test just quicker, the other reason i like radials is when you get mr builder who adds extra sockets in and take a spur from a spur because it worked fine for years on every job he has done.
As for adding sockets, its just the same as adding to a ring apart from a 4mm radial as trying to add another 4mm cable i can be hard work and with some brands of sockets impossible hence the ring final for the kitchen.
Agree 100%
Got to agree with this while some argue it's easier to install radials not using ring circuits is like leaving some of your tools in the box unused
Are you suggesting a single radial for the living room and bedrooms or a radial for each room
Doesn't stop Mr builder bodging the electrics, lost count of the number of times I've found the 8 circuit or increasing the MCB size because of nuisance tripping of the 20A breaker
Then we have the 4mm² radial and because the terminals are packed it gets extended or spurred off in 2.5mm² or some of the strands in the 4mm are trimmed back to make everything fit
The long and the short of it is there are pros and cons to each method and how each installation will be used in the future is crystal ball land as more and more power hungry equipment comes to market we may need to rethink how domestic properties are wired, how about skirting busbar systems one big radial and customer has a box of socket outlets to place where ever they want and bodged electrics could be a thing of the past.
4mm radial hate em, to much wrestling with the cable terminations for me, stick 2 RFC in 2.5 myself.
The deciding factor as for which circuit to use for me comes down to the size and layout of the property, what each room is to be used as and the budget available
All these radials, ....Your going to end up with CU'S the size of those used in many European countries, and many if not most UK homes especially the older ones have just about enough room to cater for the 17th edition CU's. Basically a waste of time and money installing ALL radials, for just for the sake of them....
Radials are a pain, did a Job in a recently rewired church. Was wired in LSF 4.0mm twin in PVC trunking. Wanted a few extra sockets, and as I couldnt put a third conductor in the back of a socket outlet already holding 2 4.0mm conductors I had to go to the end of the circuit and extend from there. Radials in 2.5 have a better future proof to them
How do you work that out, one extra circuit is going to make that much difference is it. how is it a wasted of money it is actually only one extra lenght of cable so 10m max and i was rewiring a house i would always install a board with a few extra ways so using one more isnt going to change the cost and like i said if u get a fault on one u dont lose the whole downstairs.
I've got a colleague who loves radials. The number of times I've been to places where it keeps tripping and it's just overloading. 20a radial upstairs, hair drier, straighteners, tv and a few other things. And trip.......
Makes you look like a ****.
I always stick to the kitchen RFC, upstairs RFC and downstairs RFC.
Personally it gives more room in the db and more room for usage.
As far as I read it ( this is from 17th edition 2008) unless its changed
4mm t/e 70c Reference Method A ccc = 25 amps
Reference Method B ccc = 30 amps
Reference Method C ccc = 36 amps
reference method D isn`t relevant to domestic
So if you do anything other than clipped direct over the whole cable run you cant use a 32 amp MCB anyway.
Will put on my tin hat and await the incoming fire!!!!
sunny essex
Domestic rewire radials or ring final,s ???
Domestic Electrician Forum
tuckermot,
TaffyDuck,
