Domestic shower submain | Page 3 | on ElectriciansForums
Discuss Domestic shower submain in the Domestic Electrician Forum area at ElectriciansForums.net
ChrisElectrical88
Mentor
Nearly Esteemed
Wales
We are installing a new shower, electric towel rail, light and fan in a bathroom. The existing mains board is a old wylex rewirable. Gas and water is 10mm bonding from the MET in the meter cupboard.
The existing mains board is litrelly inaccessiable at the back of a kitchen cupboard and would require multiple brand new units removing to even access, let alone getting a 10mm to for a 9.5kW shower and add RCd protection to existing circuits.
My idea is to run a submain around the outside of the building in SWA into a small cupboard next to the bathroom and have a dedicated board for the bathroom which i can then protect as needed.
However due to no access to where the supply enters the building to mount my switch fuse my only option is to put something in the meter cuoboard.
There is already a smart meter in the cupboard however not ebough room for a 63A switch fuse. There is however ebough room for a small 3 way unit, in which i plan to install a a 100A DP switch disconnector and 63A MCB. The max Zs reading or the B63 60898 will not be exceeded by the submain.
Can anyone see a issue with this or think ill get any comeback by the DNO? Cheers
No it wasnt haha. They have done an awful job which is why this current builder is in for the bathroom.
I bet they drew top dollar,and disappeared into the sunset,leaving others to receive all the abuse,and what cash is left...a very common scenario.
I have a list...a ÂŁ60,000 kitchen re-furb,with concealed,badly supported push-fit waste,popping off and flooding under the ÂŁ6,000 marble tiles... A ÂŁ14,000 "luxury" bathroom,with similar,and extractor vent,hose and switch fitted...but no fan or wiring,and,what is in my experience,the worst soldering i have ever seen :(
Ooooh,and my very favourite,of last year...a large detached new-build bungalow,with the DPC at different levels,in the inner and outer leaf,but BOTH in the wrong position...i despair :rolleyes:
Reply to Domestic shower submain in the Domestic Electrician Forum area at ElectriciansForums.net
P
16 Square Meter Domestic Bathroom Tiling Work Malton North Yorkshire I have a job in Malton North Yorkshire, and I’m giving it a try on here (you...
PETERHA
P
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
