Persons to be competent to prevent danger and injury (EAWR)
16. No person shall be engaged in any work activity where technical knowledge or experience is necessary to prevent danger or, where appropriate, injury, unless he possesses such knowledge or experience, or is under such degree of supervision as may be appropriate having regard to the nature of the work.
So far as I know this is the only statutory requirement in doing electrical work. While an industrial installation worker and domestic worker my have the same qualifications, there is no way either could do the others work. Regs talk of "skilled persons" another layer of definition.
And here is the first problem; that language used is not consistent across mediums. I get EAWR has to by its nature use definitive terms but it would help if the non-statutory media we utilise used the same language to avoid ambiguity; A classic example often given is EAWRs use of SHALL and MUST for absolute regulation, no use of unambiguous terms like MAY etc.
So statutorily: Technical knowledge, from qualifications? Experience; on the job? But the whole point of being competent, the aim, is to PREVENT DANGER AND INJURY. So work carried out must be done to regs to obviate injury and danger. Which in some ways is common sense. I think it is easily forgotten that an electricians work is not that difficult.
From a qualification viewpoint it is really just basic science nothing rocket science about it.
From a hands on tools stand point you're probably right but it's the understanding of the scientific fundamentals and how to work safely with them.
The techniques employed by a skilled experienced person are not that difficult once learnt. I do think sometimes some get a bit up themselves in presenting being an electrician as an insoluble maze of technical difficulty whereas it is very mundane and simple. Present company excepted of course.
True but to those that have no clue, as with any skill, it can be like witchcraft is being performed in front of you.
Any idiot can put wires in holes and tighten screws but it takes time, knowledge, retention to select the right wire, the right tools and all the other bits that we learn over time to truly do the job problem. Anyone can lash it in, flick a switch and see light turns on but it takes thr right kind of person to do it safely etc.
134.2.1 During erection and on completion of an installation or an addition or alteration to an installation,and before it is put into service, appropriate inspection and testing shall be carried out by skilled persons competent to verify that the requirements of this Standard have been met.
Under definitions;
Skilled person (electrically). Person who possesses, as appropriate to the nature of the electrical work to be undertaken, adequate education, training and practical skills, and who is able to perceive risks and avoid hazards which electricity can create
Just to further define what an electrician should be by statute and regs. HSE provide further info on competent as defined in EAWR. But this is all rather common sense. Competent is mentioned a number of times especially around I&T having to be competent to do I&T.
Competency is mentioned in most H&S legislation, as opposed to qualifications, presumably because the latter is a simply metric of the former.
Biggest issue in the whole thing is that (in terms of terminology) we're not all singing off the same hymnsheet; Legislators will talk of competence (because they have no financial reason to talk about qualifications).
Trainers and other organisations (set to benefit from cash changing hands - money for services that is, not bribes, although....) will talk of qualifications because it's how they make thier money,
Old timers will talk of apprenticeships being the dogs danglies because it is how they cut thier teeth and were likely no alternative routes available.
Course students will complain (I count myself in that) that companies won't give them thr time of day or accept anything other than apprenticeship due to the lack of financial reason of thrm to take non-apprentices that have "front-loaded' the knowledge so they could understand what they were doing before doing it.
It needs a collective and industry-wide shake up but that will likely not happen and so we'll still hear that Apprenticeships aren't what thry once we're, that the electrical industry needs an overhaul, that anyone that came into the industry via any route other than apprenticeship is seen as inferior or worse; isn't a spark.
I guess those that truly want it (regardless of route), will put thr work in and go and get it. I've been lucky enough to get a job with a company that specifically created roles aimed at those working at level 3 (take it to mean NVQ3 as opposed to Level 3 (2365 / 8202-30) ) and although I didn't have that NVQ3, I was able to convince them that it wasn't having that NVQ3 that made me a good choice but my study ethic, the being the 'Class of Covid', having to put in MORE work to ensure that the knowledge stuck and being able to demonstrate that in interview.
It's ---- but our own experiences are what we make of it. Life is a ---- sandwich, it's just more enjoyable if you have the palate of a dung-beetle ?
