Door Bell installation | on ElectriciansForums
Discuss Door Bell installation in the DIY Electrical Advice area at ElectriciansForums.net
Brian G
Northern Ireland UK
Hi
I want to install a door bell (front door). Cables have been installed (not by me) see attached photos.
There is a back box in the wall of the hall with two x 2 core cables coming out of it.
There is a single 2 core cable for the bell push at the front door -I have unscrewed this to show the cables.
Also there is a single 2 core cable coming out just under the consumer unit in the utility room adjoining the hall.
How do I proceed with connecting up a door bell
Many Thanks
[ElectriciansForums.net] Door Bell installation
I would forget about a wired doorbell and just get a wireless one. I've had one for years. The bell push simply sticks to the front door frame and the chime unit is totally portable. I bought mine years ago, but in 2024 there's a much wider choice of much more technologically advanced doorbells, including systems with several chime units that you can hear elsewhere in the house or even in the garden.
Although my house, new in 2004, is indeed fitted with a wired doorbell, which still works, if it suddenly stops working I won't shed any tears.
Thanks for the advise.I will look into which wireless doorbells are available. Probably a lot easier than messing around with the installed wires I have now.
From what’s there, you would also need a transformer to power the doorbell circuit, which would mean taking a 230V supply from the consumer unit.
Being a new circuit, albeit only 12 inches long, would still require testing and the services of an electrician.
You can still get the old “ding dong” type chimes that take batterys
Reply to Door Bell installation in the DIY Electrical Advice area at ElectriciansForums.net
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
