door bell | on ElectriciansForums
Discuss door bell in the Australia area at ElectriciansForums.net
K
kduck
been asked to wire in a mains door bell, would I take 1 mm from fuse box to transformer, then wire in bell wire from there to switch then back to door chime.
Be carfull what door bell you buy, I recently brought a new wired door bell from CEF and have had nothing but trouble with it, its took me 3 days going backwards and forwards trying to get it to work right. It was a nighmare.
I tried everything and couldnt get a decent "Ding "Dong" i was only getting a "Dong".
Tried 3 different bell pushes, moving the contact in the bell push.. but no joy.
In the end i brought the customer a byron buzzer. not the best sound but alot louder than a "Ding Dong" bell.
I wouldn't recomend getting what ever is the cheapest from your wholsaler. Pay that bit extra for a quality bell.
(p.s. I have always doubled up alarm cable or BT cable for bells instead of using single core bell wire. Never once had a problem with this method)
FYI, some door bells come with a facility to have two seperate bell pushes i.e one for front door and one for back door. The sounds they make are also different, front door will be ding dong and back door will be only dong. You may have had one of these????
Cheers.
I have a TracTR7 bell transformer for the bell no instructions with it. On the transformer its got mains in come with two terminals one says 220 the other 250 do I take a live and neutral to them here, which goes in which. On the output side its got three terminals one with 4V one with 12V and one with 8V do i then take the 4V one to the bell push then to the chime, then is it the 8v straight to the chime to give it 12 volts, is that right???????
You should only need 8v output in total from the transformer to the bell. not 12v
feed into the transformer with 230v, then 2 cores out (8/9v) to the door chime, then a seperate 2 cores from bell push to door chime.
you say two core out of the transformer to bell push one from 8V the other from where? or do they both come from the 8V at the transformer. Is there a neutral to the transformer? Sorry but never done one before.
No not from transformer to bell push, from transformer to door chime. then another 2 cores from bell push to door chime, (ending up with 4 cores at door chime)
This is how ive always done it, Although i think there is other methods.
Ok just to see if I've got this right. two core from transfomer both carrying load to one side of the chime. Then two core (split) one from income side at the chime to bell push and the return (switch) bell push to other side of chime.
Also is it L and N into the transformer, or just live.thanks for your help so far
The live and neutral from your mains supply go to the primary (230v) side of the transformer.
The secondary side of the transformer 8 volts in your case go to the chime.
The bell push is wired in series on the 8 volt side of the transformer to the feed going to the chime.
The bell push is normally open circuit and when pushed makes contact completing the supply to the chime.
Under no circumstance should you connect the bell push on the primary 230v side of the transformer,the bell push is only designed for elv (Extra low voltage)
Bit detailed but hope you get the jist;):)
Reply to door bell in the Australia area at ElectriciansForums.net
Just to follow up on the 'ding-dong' option that Friedland have been making for years, if you put batteries in one of those, all you would need to...
The light may have a permanent supply already inside it if you are lucky.
