Door entry with two means of access | on ElectriciansForums
Discuss Door entry with two means of access in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
London
We are using a Bell BL106-4 on the main door. Code entry to open the door, buzzers for each flat. Simple. Only now we want to add access control to a metal gate at the end of a path a mete 10m away. Am I best off adding another Bell BL106-4 at the gate and wiring in-line or is there a smarter way to manage the access in this situation?
Reply to Door entry with two means of access in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
