Rather be Fishing
Trainee
Hello guys only me with another question.
Ive just had a job come through that says the door mag is not engaging the door.
On the door is a metal plate and on the door frame is another.
When they connect they are supposed to magnetically stick them selves shut and you use a fob on the fob panel or press the exit button.
I know there's power because the fob plate is lighting up.
Any ideas on what I need to do to solve the problem
When I press the door exit button the fob pad goes from red to free but not sure if you can see that from the pics
