Doorbell buzzing | Page 2 | on ElectriciansForums
Discuss Doorbell buzzing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Please could you identify and / or provide links to the products. Is the transformer integral with the bell?
Hi. If the doorbell keeps buzz, there are some reasons.
First, maybe the doorbell is short circuit. Please remove the battery, and see if water enter the doorbell, or there are other things make the live wire link together. You can dry it with blower.
Second, maybe it is electric circuit fault. If you can not fix it by yourself, you need to ask a professional to help you.
Third, you can tell the error according to the beep. If the doorbell make one “beep” sound, it is normal; if the doorbell make two “beep-beep” sound, it is common error, you need to set it up.
Forth, the button of doorbell has a bad contact. You can solve the problem by restore the elasticity of the button.
Reply to Doorbell buzzing in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
How about one of these ? No supply needed and has the benefit of having an array of different knocks for all types of moods.
