Doorbell chime wiring | Page 2 | on ElectriciansForums
Discuss Doorbell chime wiring in the UK Electrical Forum area at ElectriciansForums.net
Richard Cook
Sheffield
Hi folks
I moved into our house a year ago and at some point I disconnected our doorbell chime and then, stupidly, managed to chuck it in the chaos of life.
I normally take a photo before I disconnect anything but didn’t this time and all I have is the photo attached of 4 white wires.
Does anyone know how to wire up a new chime? Is it trial and error or is there a system to which white wire goes to what on a new chime?
Also is there a way to check if these wires are connected to a transformer and thus use the wires at the doorbell to upgrade to a more modern doorbell (Ring, or similar?).
Thanks so much.
Rich
  • [ElectriciansForums.net] Doorbell chime wiring
I went out and looked at the bell push. Think it's knackered. I removed from the wall and used a length of wire to touch the two wires and it rang the bell! I think the terminals on the bell push are corroded so have ordered a new bell push and, fingers crossed, that should be that.
I really appreciate all the help you've given.
Glad you've got to the bottom of it!
It's obviously all wired correctly, so no, don't swap any wires round now.
Bell pushes do tend to die, especially if they are exposed to the elements!
Pleased to have helped ?
Now back to painting the ceiling.
Reply to Doorbell chime wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
