Double ferrules what size does it mean? | Page 2 | on ElectriciansForums
Discuss Double ferrules what size does it mean? in the UK Electrical Forum area at ElectriciansForums.net
G
Guest22
Hello there everyone i have a question on ferrules, i`m pretty sure that when you have a double ferrule when they are say a 1.00m2 ferrule, that would allow for either
2x1.00m2 core cables to be crimped; or
2x0.5mm2 core cables to be crimped
Please can this be clarified :)
I was just looking around on the internet and had never had to actually order ferrules, people i work with always had them!
Hopefully the panel goes well! Should start it next week!
Yeah, thank you for the tip robostar, never actually thought about how much that slotted trunking eats up space! But i might not be using it as, its only a small control circuit and apparently i should get away with neatly cable tying the control cables together.
Reply to Double ferrules what size does it mean? in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
