Discuss Double float switch fitting. in the DIY Electrical Advice area at ElectriciansForums.net
The relay is the one that was recommended with the float switch. The float switch is for use to control the level of a pond, controlling flow of osmosis water supply. There is no printing on the case .What do you mean by 'a double float switch'? One that trips a switch at a minimum level and another at a maximum level?
The relay you mention is a 4 pole change over one (4PDT). The connections for it are normally printed on the case, but it isn't obvious how or why this would be used with a float switch.
Reply to Double float switch fitting. in the DIY Electrical Advice area at ElectriciansForums.net
