Double immersion hot water tank. | on ElectriciansForums
Discuss Double immersion hot water tank. in the UK Electrical Forum area at ElectriciansForums.net
Maidenhead
Dear all,
Has anyone come accross a double immersion hot water tank. How did you supply it 2x16A circuits. Maybe a 32A circuit split into 2 with 2x 20A double pole switches. I have only come across singles before, so im trying to find the best solution as i only have 1 spare way at present.
Bottom Immersion would generally be used for night time heating of water on cheaper rates. Top Immersion for boost.
They aren't suppose to run simultaneously, just get an Immersion timeclock with boost function.
It has 2 3kw immersions i.e boiler does most of the time but incase of breakdown immersion will provide hot water.
I don't see a problem with running a 32A radial to feed both if they are designed to operate together. Still a dedicated circuit for a piece of equipment imo.
I would prob go for FCU's rather than 20A DP tho, if you are using 1.5mm flex to feed the immersions.
After reading again I'm not sure if you are suggesting running 1 T&E to each FCU from the same MCB or ' doubling up' the conductors to each FCU.
The first is a definite no.
Doubling up conductors is allowed in some situations but in this one i would say it is bad practice, plus terminating 4 x 2.5mm conductors into a MCB or FCU ain't gonna be pretty.
Just get some bigger cable.
Reply to Double immersion hot water tank. in the UK Electrical Forum area at ElectriciansForums.net
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
