Double immersion hot water tank. | Page 3 | on ElectriciansForums
Discuss Double immersion hot water tank. in the UK Electrical Forum area at ElectriciansForums.net
Maidenhead
Dear all,
Has anyone come accross a double immersion hot water tank. How did you supply it 2x16A circuits. Maybe a 32A circuit split into 2 with 2x 20A double pole switches. I have only come across singles before, so im trying to find the best solution as i only have 1 spare way at present.
Its a pretty sad state of affairs when FCU's are burning out before the 13A fuse in them pops IMO.
A FCU SHOULD be up to the task really but I understand people's concern, I've never seen one burnt out by immersion load myself but I have heard of it happening.
32A submain feeding 2 x 16A radials would be the ultimate solution but trying to convince customer he needs and extra DB just to feed his emergency back up immersions might leave a sour taste.
Luckily its a mate, but i agree with you.
Its a pain in the butt, but i will probably use 20dp switches, From a 32A feet into a cu as im not sure i will be overloading adding another 32A on the board.
I have a garage to supply power too so may install a second split load board.
Reply to Double immersion hot water tank. in the UK Electrical Forum area at ElectriciansForums.net
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
