Double pole rcbo reconmendations wanted | Page 2 | on ElectriciansForums
Discuss Double pole rcbo reconmendations wanted in the UK Electrical Forum area at ElectriciansForums.net
loplug
Cornwall
Is there a double pole Rcbo available that i can fit in a consumer unit i would like to use a doublebuss bar and have individual protection for every circuit all the rcbos that i have found so far have a flying lead for the neutral this seems unnecessary and i think the way i would like to do it would make a neater install. any one have any experience of these?
Behave yourself Buzz. :rolleyes: If the OP is serious about getting this work done to a high standard and properly tested, certificated and notified I was going to offer a visit and quote. But I'm currently booked up until the 3rd week in June.
[ElectriciansForums.net] Double pole rcbo reconmendations wanted
there you go, start by using you crayons :p
Well I genuinely thought that I may have been able to get some advice from this forum. Only to be told that this is not something I should be concerned with, and for people to make general assumptions about my qualifications and the need for the work to be notified. All of which are irrelevant to the original post and no one asked any thing about the nature of the install
You could use the search function, and find some previous threads on this subject. To my knowledge there is only one supplier of such DP RCBO's in the UK?
Have a look at this thread:
DB installed connected & tested - https://www.electriciansforums.co.uk/threads/db-installed-connected-tested.151846/page-5#post-1401387
The reason for double pole devices is to provide proper discrimination of circuits. I looked at the Hagar ones but they all have the neutral leads apart from some that are described as not for use in distribution boards.
Reply to Double pole rcbo reconmendations wanted in the UK Electrical Forum area at ElectriciansForums.net
well then, must be a fault on the circuit, a faulty appliance if a power circuit or a faulty RCBO.
Yup will do exactly that when I'm back down there. Thanks for the help
