Down lights and Polystyrene ceiling tiles | on ElectriciansForums
Discuss Down lights and Polystyrene ceiling tiles in the UK Electrical Forum area at ElectriciansForums.net
PAD66
Alsager, Cheshire
Have been asked to install four down lights in a bathroom that has polystyrene ceiling tiles. I plan on using sealed LED units so that a bulb can't be replaced with a normal halogen bulb. Have checked chapter 42 in regs, as I read it as long as the temperature does not cause a fire hazard there should not be an issue. It's a private property and they don't want to remove the tiles at present. Any advice will be greatly appreciated
thanks Paul
thanks Paul
use click connectors on the lights or lights that come with them, they will make swapping one out in the future easy and it means you can have everything ready before ceilings are up
Polystyrene ceiling are a fire hazard, they where installed 30-40 years ago as a cheap way to insulate then it was found that if they caught fire it flashed across the ceiling rapidly.
If I was you I would recommend to the client they are removed for their own safety.
Beats what I was going to say about it just looking naff!
I've seen the results of two polystyrene tile fires, both in schools; both stated deliberately by pupils setting fire to the tiles.
The fire spread instantly and gutted the corridors, the smoke damage was unbelievable.
The main cause of the numerous injuries beside smoke , was the dripping flaming polystyrene.
This was many years ago when the tiles were the new fad.
I remember me folks opting for these,in the early 70's,and due to their jobs in journalism,realising the danger,and removing them.
It was a while before they could afford re-skimming,and i recall the ceiling resembling a game of dominos....with only double fives....:icon12:
Even though fitting LED downlights would have operating temperatures at an acceptable level, it's not worth the risk of possibly being liable if there is a fire.
Also agree with Welchyboy1 nice new lights nasty ceiling.
Reply to Down lights and Polystyrene ceiling tiles in the UK Electrical Forum area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
