Down lights for kitchen with very little room above. | on ElectriciansForums
Discuss Down lights for kitchen with very little room above. in the UK Electrical Forum area at ElectriciansForums.net
Top Cat
Gloucester
Does anyone know of down lights that are quite shallow as i have only 4" including the depth of the plasterboard. I will be using LED lamps so heat is not an issue?
Many thanks.
Beg to differ!
Not going to argue, however I firmly believe you cannot reduce the fire rating or fire barrier in any ceiling, I certainly NEVER have.
Currently working on a 400year old thatch cottage, wonder what the building inspector would say if I fitted standard fittings??????????????????
Fire rated downlights are used to maintain the ceiling’s fire integrity. When a downlight is installed a hole is cut into the ceiling. This hole reduces the ceiling or floors fire rating. In the event of a fire, flames can spread through the hole and into other floors in the building. With easier access to other floors the fire can spread at a much faster rate. Fire rated downlights contain intumescent material, this material expands when it reaches a certain temperature and seals off the hole slowing down the spread of fire and enabling more people to escape.
This is an extension with a flat roof with Kingspan (i think) 6" solid insulation with foil back 4" above plaster board ( can't for the life of me think of the name as Friday night and had a drink!)
Reply to Down lights for kitchen with very little room above. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a smart lighting system for ambient lighting in a "traditional" kitchen dinning room it's a big area. I want to be able to put...
You too? I thought I was in a unique position:anguished::coldsweat:
